  #1
Old April 7th, 2007, 12:19 PM
AntsGrady AntsGrady is offline
Default 225 Evinrude gear shaft question
Hello all, quick question I'm hoping someone can answer. The lower unit has 2 shafts, 1 gear/throttle and 1 drive. This is kind of hard to put into words but here goes. The gear shaft comes down the motor and into the lower unit. At the bottom just before it goes into the lower unit it is encased in a foamy material. This is exterior and visible. My winter cover rope recently got caught up in there and took a little of this foam out as the rope was being pulled. It still looks pretty good but I don't know. I'm not a mechanic and don't know what the purpose of this is and don't know the impact if something is wrong. Can someone shed some light on this??? Thanks!!!
  #2
Old April 7th, 2007, 12:36 PM
ob ob is offline
Default
A bit hard to understand by your description but if I read it correctly I believe what you are refering to is the shift rod.There should be a rubber grommet that acts as a debris shield that is visible from the outside.If there is a foamy material present it must have been added by a previous owner.There is no part of the actual driveshaft that is visible externally.
  #3
Old April 7th, 2007, 03:35 PM
Default Re: 225 Evinrude gear shaft question
You're on the right track but I've always owned the motor so this is stock. I believe the grommet may be inside of this. I believe it is protection for the grommet but not sure. So if this has some wear and tear what would that do? Would this in some way cause problems to my lower unit? Does this make things a little clearer?
  #4
Old April 7th, 2007, 04:41 PM
ob ob is offline
The external grommet will not have negative effect on the sealing of the internal shift rod.Internally the shift rod has its own 4 bolt flange with seals.If the entire grommet that the rod slides thru was to be missing or severely torn away,it would allow cavity water to surge out around the shift rod when running but wouldn't cause any immediate problem within the lower unit.The problem would incur if the lower unit to mid-section cavity was to become engulfed with small debris.This is the primary function of the outer shift rod debris sheild grommet.Difficult for me to give an absolute opinion without viewing the damage but off hand I'd wager you'll be fine running as is.
  #5
Old April 8th, 2007, 11:51 AM
Thumbs up Re: 225 Evinrude gear shaft question
Thanks OB!!! I like your assesment and you seem to be right on track with what I am referring to. It isn't worn bad or anything but rather be safe then sorry. We worry the most about things we don't have much knowledge on and I've been a little concerned since I'm putting her in sometime in the next 2 weeks. Have a great season!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
V150 --- gear housing reassembly/shift shaft question Capt. Crunch Mercury & Mariner Outboards 2 September 12th, 2006 07:26 PM
Shaft extention question for 15 evinrude Junebug19982005 Johnson & Evinrude Outboards 1 May 20th, 2005 10:25 AM
Evinrude Short Shaft to Long Shaft Question. thebigbuck Johnson & Evinrude Outboards 8 March 12th, 2003 11:59 AM
Drive shaft pinion gear question. Jon.S Force & Chrysler Outboards 2 November 4th, 2002 05:41 PM
Prop shaft refitting question - '74 johnson 9.9, mdl # 10RL74 (long shaft) Jim McClune Johnson & Evinrude Outboards 2 August 22nd, 2002 08:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
