  #1
Old April 5th, 2007, 08:14 PM
reelfishin reelfishin is offline
Default Mercury 500 15" shaft
I picked up a boat today with a 20" transom, but it has a 15" motor hanging on it. Does anyone know if a 15" Mercury 500 can be converted to a 20" shaft length?
I'm doing a motor swap anyhow, but would have more uses for this motor if it were 20". Even my smaller aluminum boats have 20" transoms.
  #2
Old April 5th, 2007, 08:53 PM
OldMercsRule's Avatar
OldMercsRule OldMercsRule is online now
Default Re: Mercury 500 15
Probably not worth the cost to add a section. I bet the motor is not new. Sell it to someone with an older 'short shaft' boat or buy one yourself and hang it on the proper boat. JR
__________________
A proud n' rare Independent Cornservative from the Seattle Metro area, who runs the finest old black boat anchors money can buy!
  #3
Old April 5th, 2007, 11:28 PM
The motor is super clean with good compression, the only bad is another stuck Merc Prop. It don't look like it's been used much. Someone started to rig it on a trihull, both the boat and motor are pretty clean, especially for their age. The motor came from freshwater as well, so it's not all pitted. It's got some minor paint loss, but mostly from handling. I've only gone so far as to make sure it runs, but all seams fine so far. Some minor touch up paint here and there and a fresh prop, it'll look nearly new.
It's got almost 150 lbs per cylinder, in the top 3, and I have no reason to doubt the bottom one, but didn't have an adapter to make the bend for the lower cylinder. The last owner bought it from an estate sale, but got the motor and boat separately. I take it that he knew very little about boats, and got frustrated when he found out that the two wouldn't work together.
I could make a motor plate, but I have a matching motor for the boat. I guess I'll set it on a stand until something come along.
Did they make spacer? Was it oem or an aftermarket deal?
I had a Merc 500 long shaft but just sold it.
I don't remember that having a spacer?
I can't remember the last time I found a good 15" tansom hull that would handle a 50 HP, let alone one this old or heavy.
I have two aluminum hulls here, both are 15' with 20" transoms.
  #4
Old April 7th, 2007, 09:22 PM
agitator agitator is offline
Default Re: Mercury 500 15" shaft
Pretty raunchy looking prop ya got there too. Not much lost if you cut it off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Long or Short Shaft Mercury? mbnjagn Non-Repair Outboard Discussions 0 August 31st, 2006 11:53 AM
Mercury 18"...is this a long shaft or short? Leicacat1 Non-Repair Outboard Discussions 6 August 19th, 2006 07:38 PM
25 HP Mercury Bent Prop Shaft ehenry Mercury & Mariner Outboards 4 May 10th, 2005 12:07 PM
Needed: Mercury 500 Shift Shaft slowgypsy Mercury & Mariner Outboards 4 September 25th, 2004 05:58 PM
mercury lower shaft (25hp) sms02 Mercury & Mariner Outboards 1 June 8th, 2002 08:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
