Re: 5 hp Briggs & Stratton Outboard Info
You'll be much happier with a older Johnnyrude or other small motor. I just unloaded my B&S and was happy to do so. That said, it never failed me, always started. Depending on the application, it will rattle your teeth out. You CANNOT use them on a jack plate if you were thinking about using this motor as a kicker. It vibrates wildly and shakes the whole boat anywhere beyond idle speed. The motor is fragile and exposed with lots of plastic parts, but careful handling keeps it safe. Personally I wouldn't recommend one.
