1988 85hp Force outboard - Have had troubles with tilt since I acquired the boat this past summer. Worked OK most of the time, but always leaked down in just a few minutes when lifted up to launch or reload boat. Usually popped circuit breaker several times before I could get the motor lifted and wiring from tilt motor was getting hot. I believe the boat came with a 2 wire motor and was changed to a 3 wire by previous owners. I'm in the process of cleaning and rebuilding the whole unit but I'm wondering if I have the proper relays or solenoids for the 3 wire motor. What I have look to be relays with the following markings. Bosch / 12V20/30A 0332204150. Any ideas??
