1999 enevrude 15 hp 4 stoke
teamADR
I was out fishing the other day and was driving up river on plane. when all the sudden I lost power to my prop. I let of gas and and prop engaged again. after that happened every time i would try to throttle up my prop would disengage. the best way i can describe it is, just before the boat starts to plane in feels like a clutch slipping in a car, the motor revs up but seems like prop quit turning I let of gas prop starts turning again. It doesnt make any unussuall noise seems to stay in gear. this motor is in excellent shape and working order I am positve i didnt hit anything . Also it was very cold out that day and water temp was 40 degrees if that matters. any suggestion where to start to look would be appreciated.
WillyBWright
Re: 1999 enevrude 15 hp 4 stoke
Sounds like your prop hub is slippping. It might be the cold that caused it to fail, or you might have skimmed a sand bar. Remove it and you might see shiny metal where the hardware meets the prop. That can be an indicator. It might work OK in warm water.
steelespike
Probably a spun hub on the prop.Easy to check.Remove the prop and mark with indeleble ink across the underside.Run it and see if the mark shows movement.There is a slim chance you picked up some junk on the prop causing ventilation.Most everyone knows to reverse to check for a fouled prop.
A spun hub is an easy repair for a prop shop.
teamADR
teamADR
thanks for the tip i have a extra prop i will switch them out and take the old one in to see if the hub is spun
