Re: Anyone ever hear of a ...
definately minn kota for your needs... a much sturdier peice of machinery, and you want to go 55lbs thrust... this is the most you can go before going 24v...
also make sure you use good marine grade sealant to plug the transom mount holes from where the old motor was...
you can check out the specs on minn kota transom mount trolling motors here
http://www.iboats.com/mall/?view_id=52220&cart_id=929761727&session_id=389852930
not a whole lot of good pics here but youll get the idea, and just use the manufacturers specs for shaft leangth ( but youd probably do good w / 36" shaft )
and i say go with minn kota for their new cool quiet running motor system, as well as their new pulse system that allows for longer usage.
i personally have a minn kota bow mount 55lbs auto pilot... it is the best trolling motor i have ever had...
but if your budget allows, you can allways get one of those electric motors, but i have now experiance, good or bad with those...
and i think you can buy a good minn kota trolling motor at walmart, i dont support the walmart, but you cant beat a good open box deal!
another thing you might want to get is a cheap fish finder, sportsmans usually has em on sale, and i think there is a few here that will do... you want one that has a shallow water alarm ( most of em do ) but thats all you need it for, dont spend more than 50$... and that will meet all your needs im sure of it...
and if you are going to be using a trolling motor, you definately want two batteries, and a small batter life meter, they can be a great tool, they tell you how much life is left in the battery, and they only cost 10$... and you also want a good battery charger, ( and dont forget to check your water levels often)
well as you can see, once again i am bored at work, so ill stop before i bore you...
cant wait to see the pics of your project...
let me know if you have anymore questions..
p.s. sorry iboats for the competitor plugs...
