henry newell
Thread starter- Joined
- Feb 2, 2007
- 7
hi this is my first post. i have a 1988 johnson outboard model number d100wtlm 1600cc v4 commercial motor 100hp with a v6 gear case. the power pack has a built in rev-limiter of 6100rpm. i had a hydrylic psi dyno test at
the prop with 2400psi at 5000rpm. they set the idle
speed at 700rpm and the timeing at 28 degree btdc.
does this sound about right? i am getting 110psi on all four cylinders. i also have disconnected the vro and mix my gas and oil at a ratio of 50:1. i also looked in the spark plug hole and there was no scarring or discoloration on the cylinder walls but i did notice some pitting on all of the pistions where they
slants down. is that normal or what could have caused it? is this motor in good shape for a 1988? and do you think it will last for a few more year with regular
maintenence? i would like you opinion about this motor and its reliability. thank you
