  #1
Old April 1st, 2007, 10:39 PM
greg98926 greg98926 is offline
Default 9.9 evinrude 1974-75 oil leak
first off i am new to outboards and just purchased this motor the guy said it has sat in his garage for a few years but it ran finedi have a 9.9 and when i run it it seems to run fine but in the garbage can full of water there is oil that floats to the top after it sits for awhile after running the motor and shutting it off. . it is like a brown milky mud. almost smells like gear oil. where the prop is there is a hole in the center for the nut that holds it on i think it is coming out of there. and i also have another question. is there sapose to be water coming out of the back of the motor t wards the bottom of the lower unit where the shift rod comes out of the power head to the lower unit there is a small gap around 1/2 in ? thanks i hope someone can help have fun
  #2
Old April 2nd, 2007, 07:14 AM
lark2004 lark2004 is offline
Default Re: 9.9 evinrude 1974-75 oil leak
The oil the garbage can may just be unburnt oil from the exaust. You can always check your gear oil for water buy draining a small amount out of the gear case. If it is milky then you have a leak, if it's black then you need to change it, if there's chunks of metal..... you get the idea.....
The Prop shaft is solid. It can't leak oil like that.
The water coming out of the leg above the lower unit is normal. It's just water draining out of the exaust housing.
  #3
Old April 2nd, 2007, 10:48 PM
thanks for the info. i will check it tomorrowd.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
H2O Leak at gearcase/lower unit boltup-1974 Johnson 115 hp tbeaun Johnson & Evinrude Outboards 2 August 6th, 2005 10:10 PM
1974 Evinrude 115 surprise Johnson & Evinrude Outboards 3 February 9th, 2005 12:54 AM
1974 evinrude 135 patman Johnson & Evinrude Outboards 5 June 29th, 2003 04:34 AM
1974 evinrude 85 hp with pic JJOKER023BENTLEY Johnson & Evinrude Outboards 0 July 10th, 2002 08:16 PM
1974, 25 HP Evinrude Crappie_Fan Johnson & Evinrude Outboards 2 January 11th, 2002 03:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
