  #1
Old April 1st, 2007, 07:50 PM
shadetree918 shadetree918 is offline
Default pontoon prop blowout,cavitation,vent.?
I have a 91 Lowe 24' toon with a 78 Evinrude 140hp running a 13.25 x 21p prop (not exactly sure about the dia. but pretty close). Problem is the engine will act like I threw it in neutral at full throttle or the prop fell off. Really does this quick if I hit the gas hard but if I ease into it slowly it still does it but not as fast. RPM's shoot way up to about 6000 or so til I cut the throttle back. I am actually going slower that a toon with a 90hp. should I try a higher pitch or what? Thanks.
  #2
Old April 1st, 2007, 08:49 PM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: pontoon prop blowout,cavitation,vent.?
Sounds like a spun hub, and a 21 on a toon is crazy. I'd think a 17 would be far more likely. 21 is for planing boats. Your motor needs to turn 5500rpm at full throttle under an average load. I'll bet you're nowhere close when it's working right.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old April 1st, 2007, 10:22 PM
how can I tell if it is a spun hub? why is a 21 crazy? I can never get to full throttle, "blows out". I may be able to get to half running about 3000 but not sure if the tach is correct. By the way the prop is a 12.75x21 aluminum. How low should the prop be setting in reference to the toons or whatever? There are existing 1/4" holes in the top of the anti-cav plate from one of the hydrofoil doohickys. Could this be a problem? Do I need to repair the holes.
  #4
Old April 2nd, 2007, 07:50 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Scribe a Line across the end of the Prop, marking the prop body,+ the Hub.....
Then Run it,+ induce the Slippage.....
Shut it Down,+ Recheck your Line,.......
Chances Are,.... The Line won't line up anymore.....
If Not, Replace the Prop,+ Try Again........It'll probably be All Fixed......
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #5
Old April 2nd, 2007, 03:56 PM
Ok, will try that as soon as I can get it back in the water. Thanks for the help.
  #6
Old April 3rd, 2007, 05:57 PM
kp913 kp913 is offline
Have some cup added to the propeller, this will help alleviate the blowout problem you are having.
  #7
Old April 3rd, 2007, 10:09 PM
Do I still need to replace the prop with a lower pitch like a 17 or so? I have a 21 now and it is brand new. About how much does it cost to add cup to a prop?
  #8
Old April 4th, 2007, 07:00 AM
kenmyfam's Avatar
kenmyfam kenmyfam is online now
You need to check for that spun hub first. Then verify the tach and see what your WOT rpm is.
Chances are that with a 21" pitch on the toon you are way overpropped. I would be thinking a 15" pitch to try out first.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #9
Old April 4th, 2007, 07:16 PM
Well, I tried turning the engine over with the prop while in gear and it turned the engine. Didn't seem like a spun hub although it does "give" a little, supposed to do that right?
  #10
Old April 4th, 2007, 10:26 PM
Frank Acampora's Avatar
Frank Acampora Frank Acampora is offline
Your prop has a rubber insert between the hub and the prop body. This hub and rubber insert combo is pressed in with a big hydraulic press and plenty of lubricant. Its purpose is to "cushion" the prop shaft and help prevent damage in the event of a prop strike. ---Maybe---
"Spun hub" refers to this rubber insert wearing out or deteriorating and no longer gripping the prop body tightly. Thus when you apply too much power, it slips inside the prop body and you lose thrust. So, if you scribe a line as directed above, you will quickly see if the hub is spinning within the prop body. If your 21 prop is brand new, take it back if it is indeed slipping and see if the dealer will repair it. Don't despair if he won't though. Rehubbing is not too expensive.
  #11
Old April 4th, 2007, 10:29 PM
BTW even with a spun hub, turning by hand, you cannot generate enough force to make it slip.
  #12
Old April 5th, 2007, 07:33 AM
kenmyfam's Avatar
Have to give it true "load" conditions to check for the spun hub.
__________________
  #13
Old April 5th, 2007, 12:08 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Could be cavitation too. Try trimming the engine in when it does this. You may have it trimmed out too far and the prop is "Blowing out". I would have no more than a 15" pitch prop on that set-up....Do you have a tachometer on the boat? If not, adding one would be a good idea...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #14
Old April 5th, 2007, 11:14 PM
Does it with no trim on the engine. I have a tach on the boat but not sure how accurate. Going to get a portable tach and add to engine to see if there is a difference between the two.
  #15
Old April 8th, 2007, 01:07 AM
walleyehed's Avatar
walleyehed walleyehed is offline
Just to add a note to this..I have a customer with the same toon with a newer 115 (Same as your older 140) and at 3200ft it will turn a 14X13P at 5700 RPM...set up by myself. at or near sea-level, I would guess your correct prop to be in the 15P range to get the proper RPM.
  #16
Old April 8th, 2007, 01:44 PM
What diameter prop should I use with the 15p or 17p prop? I have a 12.75d now. What about those "hydrofoil" and "dolephin" add-ons to the engine? Had one on there and removed it when I moved the engine to the toon. Thanks for the help.
  #17
Old April 8th, 2007, 09:12 PM
walleyehed's Avatar
If the foil would help in eliminating venting then yes, but your diameter of 12-3/4 sounds like an older omc prop. If it were me, I'd be looking for a 14X15, or 13-3/4X15, (both cupped) to test..I don't think that will be far off from 5700-5800.
  #18
Old April 9th, 2007, 11:31 PM
the 12-3/4 prop is brand new, I guess it could have been an old brand new prop. I will ask my prop shop dude if he has a 14x15 prop I can try. Will that size fit on my 140 rude without hitting the plate? Thanks again for the help.
  #19
Old April 11th, 2007, 02:36 AM
walleyehed's Avatar
the 14's designed for V4's will clear just fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop blowout cavitation/ventillation w/115 merc jameservin Prop Questions and Topics 40 January 30th, 2009 07:01 PM
Prop Blowout Dirty Worm Boat Topics and Questions (not engine topics) 5 July 3rd, 2004 11:57 AM
pontoon cavitation Dirty Worm Boat Topics and Questions (not engine topics) 1 June 30th, 2004 07:10 PM
115 Merc prop blowout????? donnisreese Mercury & Mariner Outboards 2 July 15th, 2003 08:53 PM
pontoon prop cavitation Guff Boat Topics and Questions (not engine topics) 8 June 26th, 2002 12:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
