Hello All
I've got a 2002 Yamaha VX225 Ox66 3.1 EFI motor(VX225TLRA). It has a vibration in it around 2300-2500rpm, can be felt in neutral or in gear and is not prop or lower unit related. (tried other props, checked prop shaft and it is spot on).
It smokes a lot at idle, especially when starting after sitting or cold, but is generally very smokey. I think fuel consumption is high - 2 gallons per hour at idle in neutral at 730rpm for example.
At steady 3000rpm, the o2 sensor reads between 200mv and 400mv, generally around 250-330mv. At idle it generally stays above 650mv, but fluctuates between 550mv and 900mv. Generally around 800mv.
I cleaned the old sensor but the results did not change. A new sensor still gave the same results.
Have also cleaned the VST needle, checked 3 low pressure fuel pump diapraghms, sync and link, oil linkage adjustment and checked plug caps (all same, about 5k or whatever the service manual said).
Motor currently idles at 730 when warm and 850-900 when cold. I know it should be 1200 when cold - what should I check for this?
I read a lot here before posting!
My questions:
* is my o2 sensor reading OK at 730rpm idle? If not, what could cause this?
* is there any cylinder shutdown between 2000rpm and 3000rpm on these motors.
* Any suggestions re warmup idle being only 850-900rpm and not 1100?
Rodbolt says here http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=30;gtid=969224;gpid=969235 that a VX225 "will cut cylinders 2 and 4 when the shift switch is activated from idle to 3000 RPM". Does this mean that some cylinders are shutdown when in gear at up to 3000rpm? If so, can this be bypassed so that all 6 run all the time?
Any suggestions on what to do next would be apprecaited.
Thank you
My questions:
Thank you
