  #1
Old March 29th, 2007, 05:51 PM
phralh phralh is offline
Default flywheel nut 1971 evinrude 6hp
I've posted about this motor before - last fall, during a storm, boat and motor sunk. It survived and I've had it started since. Since it was only running on one cylinder I decided to check ignition and change coils. Problem is, I tried to remove flywheel without a puller, with no success. Bought a puller, pulled flywheel and did what I intended to. But the initial attemt to pull flywheel seems to have damaged the threads on the crankshaft. It's minor damage on top thread, noting I can't fix. But I didn't notice until I was puting it all together, and now the threads on the flywheel nut is pretty much gone. So, I need a new nut. I've contacted several dealers and shops around here (sweden) but noone seems to be able to help.. Also been watching eBay with no luck. If anyone have any suggestions, or a nut to offer me, it would be much appreciated! According to brp parts list, any 68-79 6hp should fit? Would any other models fit, even though they don't share the same partnr?
  #2
Old March 29th, 2007, 07:09 PM
R.Johnson R.Johnson is offline
Default Re: flywheel nut 1971 evinrude 6hp
I have' nt measured the thread but I would guess that to be about a 1/2-20 thread. A good reason not to try to knock the flywheel loose with a hammer. These are not lawn moyer engines'. You can buy a external thread die to clean up the thread's on the crank. Don't try to go all the way down with the treading die. It won't like that on a heat treated crank.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
torque for flywheel on 1971 Johnson 40 hp eddyf Johnson & Evinrude Outboards 2 September 1st, 2005 11:22 AM
Pulling flywheel on 1971 40HP evinrude outboard motor jgheck Johnson & Evinrude Outboards 1 June 24th, 2003 07:13 PM
Pulling flywheel on 1971 40HP evinrude outboard motor jgheck Johnson & Evinrude Outboards 0 June 24th, 2003 07:12 PM
1971 Merc 400 flywheel troubles. Roger2 Mercury & Mariner Outboards 2 November 29th, 2002 07:49 AM
1971 Evinrude 18 or 1962 Evinrude Lark IV comments Robdogg Johnson & Evinrude Outboards 1 October 31st, 2002 11:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
