which spark plugs do I need and which carb for 1980 omc 140 hp stringer 400 seri
sikz3
which spark plugs do I need and which carb for 1980 omc 140 hp stringer 400 series? I know my current carb is a rochester 17059053 but I boats shows my engine needing a 17059052. which is it?
Boatist
Re: which spark plugs do I need and which carb for 1980 omc 140 hp stringer 400
Spark plug was in 1980 a AC MR43T.
Changed to a Champion RV8C.
Changed to a CHampion 121.
If you like another brand then cross it from the orignal AC MR43T
Spark plug was in 1980 a Champion MR43T.
Actually,.........
The Recommended Sparkplug is AC, MR43T........
Gary H NC
The rochester # shouldn't make a difference...both are the same carbs.Looking up the rochester id says thats a 79 model 2GC..
So if your needing a rebuild kit it does not matter.
The 2 barrel rochester kits work on most early 70s to late 80s carbs.Some have the choke on the top and some on the bottom.
You can always google rochester carb ID numbers.
Look on flyingfish.com,they have pics of all the rochester carbs.
Oh,the AC plugs i think changed the number from the MR43t or whatever to something else...can't remember the new number but napa had them..
LtCmdr P.K.-G.
Re: which spark plugs do I need and which carb for 1980 omc 140 hp stringer 400 seri
if in doubt about the right heat value just an 8 or 9 in.If it cokes up lower value, if whites up up the value.
