Re: ligtly rebuild 235 engine?
those 235 engines are a son of a b.they are over bored to points that the cyl. walls have little left.that causes many problems,one,the ports crack easy when overheated,or pushed hard,the alum up by the top of the cyl,where the head gasket seats often corrodes to a point that just the steel sleeve makes the seal with the head gasket,allowing failure easy,you say you have a broken headbolt,that needs to be fixed,but I got to think you may have an eng.run in salt water,if so,be certain to look this engine over real well.
if you have it apart,with pistons out.look with a flashlith ate the port holes in the cyl.notice if you see line cracks between,if you see any,that sleeve needs to be changed,you wont get away with just honiing that block and sticking new rings on the old pistons,the cylinders need to be round with a boring,the exhust plates on the eng,should be resurfaced guareeting an even seal to keep water out,once taken apart,you need to do this.there is no lightly rebuilding those large bore crossflows,you will suffer constant problems
