  #1
Old March 28th, 2007, 06:14 PM
santander santander is offline
Default 2001 8 hp mariner putters out and then won't start.
I have had this motor for a month now and have never had a problem with it, until today. Yesterday i installed a new bulb and fuel line running from the gas tank (which is a old school metal one from the 70"s or 80"s) Tried it out in a garbage can and it worked fine, it actually reved higher and faster than with the old leaky line and bulb. So today i go fishing and after about a mile the motor starts bucking and then dies. Restarts a few times the nothing. once back at the ramp i tried it again and it started but then sputterd out and then wouldn't start. I got it home and now it won't start at all and the rope is harder to pull. Any suggestions?
Fuel, spark , both? Also the kid that sold me the motor said that on this kind of fuel tank the vent is supposed to be closed so thats how i used it and it worked fine. But know i'm not sure if thats right.
  #2
Old March 29th, 2007, 04:41 PM
Default Re: 2001 8 hp mariner putters out and then won't start.
looked at it today and it seems like there is some black gunk dripping out of the spark plug holes not much though. Does this sound like a fuel or spark problem? Also i thought that because we have had some pretty hot days lately that some gunk might of come unlogged in the carb and clogged her up. If i bring it to a mechanic how much would a carb rebuild cost on a newer 8 hp motor.
  #3
Old March 30th, 2007, 09:26 AM
Texasmark's Avatar
Texasmark Texasmark is offline
'01 isn't that old for being all gunked up but who knows. May be it's environment.
Look in the archives for "decarb" and try that first. All it costs is a little time and a $5 bottle of Sea Foam......maybe a couple of new plugs if you can't clean up the old ones.
Sounds to me like your engine uses fuel faster than it can be replenished. May be a stuck float.
If the engine has been sitting up for a long time the decarb should get you going. Otherwise you will have to dismantle and clean it up.
Charges? Depends. Probably a couple hundred bucks at least to have the carb redone.
Mark
  #4
Old March 30th, 2007, 08:58 PM
talked to some people today and they suggested that because the boat and tank had been sitting in the hot direct florida sun for 6 hours before i took the boat out, there might have been condensation in the gas tank which made the gas go bad. Is this possible? Every other time i take the boat out the boat had been covered before hand, but this time i brought it to work were it was allowed to sit in the sun for a long time prior to going out.
  #5
Old March 30th, 2007, 09:00 PM
Also i was able to start it on the the same fuel today and it ran rough for about 20 seconds before kicking off. i guess i just need to see if fresh gas will help.
  #6
Old March 31st, 2007, 01:44 AM
old merc old merc is offline
I assume you've tried it with the tank vent open? I've got a pair of old metal tanks and they must be open otherwise motor stalls out.
  #7
Old March 31st, 2007, 02:13 AM
Vlad D Impeller's Avatar
Vlad D Impeller Vlad D Impeller is offline
It appears that your new fuel line may be the problem,check the fuel line for air leaks and make sure that the primer bulb is facing the correct direction.
__________________
'The past is history, the future is a mystery,
and now is a gift. That's why it's called the present'
  #8
Old April 4th, 2007, 07:01 PM
well over the past week have tried a bunch of stuff including checking spark on both plugs (good), i assume this means my coils are good?, sprayed carb in and out with sea foam deep creep, attached air hose to carb fuel inlet to blow any crap out, tried differnet gas tank but the fuel was just as old as the one thats in my usual metal tanks( couple weeks old, been sitting outside). so after these tests i have been able to start the motor but it eventually putters out unless i give it gas. Could this be from bad gas still (i really should just empty my usaual tank and get some fresh gas), also if there was water in the gas does this mean the carb should be rebuilt? and could this be causing the motor to die with out throttle?
thanks so much for the help,
im an idiot :%
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 Honda BF9.9A rough start jsty40 Honda & Tohatsu/Nissan Outboards 1 September 19th, 2006 02:37 PM
2001 FICHT 175 won't start AUEE97 Johnson & Evinrude Outboards 6 May 29th, 2006 05:01 PM
2001 75 merc will not start Erictheredone Mercury & Mariner Outboards 8 March 14th, 2006 08:03 AM
2001 Suzuki DF 9.9 electric start imported_JD__ Yamaha & Suzuki Outboards 1 June 10th, 2005 12:49 PM
2001 Yamaha Vmax 200 H.P EFI won't start jlp Yamaha & Suzuki Outboards 0 July 18th, 2003 06:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
