Re: 2002 Evinrude Ficht 250's
Put a piece of 5/16" clear hose on the water outlet of the EMM and run it to the transom well. Run the boat at all speeds and watch the water flow, especially if there are air bubbles in the line. That would mean the motor is not getting solid water at the gearcase inlet screens due to a transducer, thru hull, etc. mounted to close to the motor's centerline.
The dealer can order high flow water inlets if that is the case.
Have the brass fittings for the water lines at the powerhead base been removed and checked behind them for shell, sand, debris, etc ?
