  #1
Old March 26th, 2007, 12:37 AM
Tim1993 Tim1993 is offline
Default 40HP Mercury Tilt Trim Switch Prob
The up trim switch on the gear shifter works intermittenly. The down works everytime but not the up. How can I trouble shoot or maybe to correct the problem? I have sprayed contact cleaner in the switch itself but no change. The motor has rocker switch on it and works perfect there.
  #2
Old March 26th, 2007, 10:57 AM
Silvertip Silvertip is offline
Default Re: 40HP Mercury Tilt Trim Switch Prob
The fact that the switch on the motor works says the remainder of the system (motor, relays, and wiring) is ok. The trim switch in the control handle is apparently going south and should be replaced. Before doing that though, make sure the connection to it is ok. You might also disconnect the large harness plug at the engine and check it for corrosion.
  #3
Old April 23rd, 2007, 11:21 PM
It is still working intermittetly and that is getting annoying so tonight I tried to tear into it with no luck. How do I get into that rocker thumb switch? I had the entire throttle housing apart but it still would not let me into the switch area to check the connection. If there is a diagram or pictures anywhere I would appreciate it. Also is there any springs or surprises in there that I should know about before hand?
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
replacing trim/tilt switch in mercury shifter bbcullen Mercury & Mariner Outboards 6 March 8th, 2007 04:38 PM
please help force 125 tilt trim prob laurieandmike Force & Chrysler Outboards 1 June 11th, 2003 05:00 PM
Trim and Tilt Switch Mercury Controls JERSATX Boat Topics and Questions (not engine topics) 1 January 2nd, 2003 04:49 PM
tilt and trim limit switch on mercury msbadhabit Mercury & Mariner Outboards 3 December 29th, 2002 07:09 PM
tilt trim prob chrisvan Mercury & Mariner Outboards 1 October 1st, 2002 04:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
