Re: 1962 Johnny CD 18 5 1/2hp plug type?
Just a few years ago, Champion strangely changed their recommendations (with OMCs blessings) for most motors that originally specified the J4s to RJ12s. Why change now? J4s worked for decades and they still work today. 32:1 with any outboard oil should work fine. 24:1 using originally recommended crankcase oil fouls plugs, and is a bit richer than necessary for modern outboard oil. If you do go 24:1, stick with the hotter RJ12s to avoid fouling. But then, outboard oils don't foul nearly as readily as crankcase oil did.
( If it was mine, 32:1 with J6Cs. )
