biederboat
- Feb 13, 2005
- 89
This may be my final question on this thing, depending on whether or not I can fix it. 1996 90 HP Force, blew a head gasket, which froze a cyl. I got it unfroze, middle pistion (where the gasket leaked) has bad compression (50 psi), other two good (about 140). Took the head off, bore looks good, must be shot rings. I took off carbs & manifolds & reeds, it looks like you could remove the connecting rod cap screws (by moving the middle piston to bottom dead center) to remove the piston assembly out via the cylinder head end. Has anyone ever done this? I'm thinking that's about the only way I could do a cheap repair on this thing. I'm just not thinking it's worth it to disassemble the cyl head. Any comments, hopefully based on experience? If I can't do this, it'll become a scrapper and await a new 4 stroke, which is really what I want anyway but just want to know if it's worth a shot.
Thanks,
Biederboat
Thanks,
Biederboat
