I'm trying to get into the control box of my 73 115 Johnson. I've removed the bottom plate (cover) and removed the black cushion from the top. I've also removed the throttle lever and warm-up lever, but I cannot get the top/front cover to budge. What steps do I need to take to remove this panel so I can get full access into the control box.
I'm trying to access the box for a few reasons: The previous owner cut the choke toggle wires within the box and conected the choke solenoid to the ignition so that when the key is turtned the choke is initiated. I would like to connect the toggle switch back to the choke. I would also like to check my tachometer connection. Apparently I disconnected something while installing a new fishfinder (I don't think the problem is in the control box but I'd like to check it if I'm in there. I would also like to clean-out a dirt dobbers nest thats within the box.
Any suggestions?
Any suggestions?
