  #1
Old March 21st, 2007, 12:35 AM
george3405 george3405 is offline
Default Evinrude 48 spl (1989) ignition timing
As many of you already know my engine only backfires out the exhaust and will not start. Anyway to check/set the timing with the engine not running? Thanks again for your help and your patience.
George 3405
  #2
Old March 21st, 2007, 09:55 AM
steelespike steelespike is offline
Default Re: Evinrude 48 spl (1989) ignition timing
George,You shouldn't do new posts on the same motor you can bump your post up with your new problem/Q it's impossible to keep track of the process of your motor.
That said,you really need to be working from a manual
there is a timing procedure in the carbutor section.and there is a testing procedure in the ignition section.these are both too involved to deal with here.If you can't afford a manual you may find one at the library.You'll need to get a card but no cost and they usually can order a book if they don't have one.You can order aftermarket manuals right here,amazon.com,or even at NAPA auto parts.I got mine off eBay.2 "Intertec" manuals covering many brands one under 30 hp and one over 30 hp.69-89.These were close to new.
about $30 for the pair including postage.I have seven manuals mostly to help here I like giving folks a hand
here it's a kick when they solve their problem.
Be sure to keep us updated with your progress and any further questions.
  #3
Old March 21st, 2007, 04:23 PM
Spike,
Thank you for the advice about "bump". I apologize for not knowing and doing that. Right now I have a manual by Clymer which covers several years & models of Evinrude. All of the procedures refer to timing the engine only with it running. I think I'll have to buy the factory manual. Anyway, again many thanks!
George3405
  #4
Old March 21st, 2007, 04:54 PM
F_R F_R is offline
The manuals won't say anything about timing when not running, as you have found out. I suppose you could get some kind of idea where it is firing while cranking, but the specs would be by guess and by golly.
  #5
Old March 21st, 2007, 10:54 PM
F_R F_R is offline
Actually, any engine should spark right around top dead center, give or take a hair before or after when starting. Now if you can figure out when yours is doing it?
  #6
Old March 22nd, 2007, 08:25 PM
Silvertip Silvertip is offline
Have you checked the flywheel to make sure the key has not sheared or partially sheared. The key locates the flywheel in the proper relationship to the crankshaft and hence timing cannot get drastically out of spec unless someone has messed with the advance linkage. Those specs are covered in the link & sync procedure in the Clymer manual. Those adjustments are done with the engine stopped using a ruler. The manual covers multiple engines to be sure -- all you need to do is follow the procedure for "your" engine. which are 40 & 50 HP and the Jet. Follow that procedure to the letter. Once the engine is running, you can check idle timing and you will need a test prop or dunk the boat in the lake, left on the trailer, and then check the wide open throttle timing.
  #7
Old March 22nd, 2007, 09:14 PM
The flywheel key is not sheared. It turns the crank even when I turn the engine by and. All I found in the Clymer book is the adjustment for the Throttle cam follower & wide open throttle stop adjustment. The maximum spark advance adjustment has to be done when engine is running. When I crank it over it either backfires or does nothing, but crank, and once in awhile it binds up like a car engine with the timing is off. ?????:'(
  #8
Old March 29th, 2007, 02:00 AM
bump: I shot some WD40 into the cylinders and ran the pistons up and down w/o plugs. Now there is no binding, but the best I get is a back fire. All wiring is ciorrect. The fuel previously had so much water I could not smell anything. I pump out (w/ the primer bulb) about 1/2 the tank til I got strong fuel odor. Then I installed a water separator fuel filter. Still backfires and will not start. What is the best way to drain all gas out of the tank (maybe I should say fastest way). Will bad gas make the engine backfire out the exhaust. I think #1's piston rings are stuck because I get 120/lbs on # 1 cylinder and 150 on cylinder# 2. I am determined to get this engine running.
Thanks again,
George3405
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 OMC 3.0l timing??? CodyG Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 August 8th, 2005 06:36 AM
Evinrude 70 -1990 ignition timing bokarlsten Johnson & Evinrude Outboards 1 May 26th, 2004 12:05 PM
1993 Evinrude Carb/ignition sync/timing zspinner Johnson & Evinrude Outboards 1 July 8th, 2003 05:56 PM
1989 125 HP Timing DJestes Non-Repair Outboard Discussions 0 July 29th, 2002 07:22 PM
ignition timing 50hp johnson (1989) jeryve Johnson & Evinrude Outboards 1 April 6th, 2002 06:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
