  #1
Old March 20th, 2007, 07:52 PM
BagOFchips3071 BagOFchips3071 is offline
Default 135 EVINRUDE IGNITION WIRING DIAGRAM
Removed the ignition switch to have a key made for it after losing the first one. Got the key and now have to re-install the ignition switch but I'm not sure of what wires to attach to what terminals on the switch. I dont know the exact year of the motor but I'm fairly certain it is from the early to mid 70's since it has the old style 5 terminal switch as opposed to the newer ones I've read about on here that have 6 terminals. On the back of the switch, the terminals are labled: B, M, S, A, M.
The color of wires are: 1 Red, 2 Black, 1 Black with a yellow stripe, 1 Tan, 1 Purple, & 1 Purple with a white stripe.
The choke is on a separate switch, which I believe is why I have the 5 terminal switch as opposed to the newer 6 terminal switch that incorporated the choke into the same switch. The purple wire with the white stripe on it is what connects the choke switch to the ignition switch. (The key had to be in the "On" position to activate the choke.)
I would greatly appreciate it if anyone out there can tell me which wires go where. Thanks.
  #2
Old March 20th, 2007, 08:10 PM
F_R F_R is offline
Default Re: 135 EVINRUDE IGNITION WIRING DIAGRAM
Red to B (bat)
black to one of the M (either one)
black/yellow to the other M
Tan is probably dirty white- goes to S
All Purples goes to A
Purple/white is the choke wire - should go the the choke switch
There should be a jumber from A to the choke switch to feed it.
  #3
Old March 20th, 2007, 09:18 PM
Thanks for the wiring scheme. I hooked it up like that but it still doesn't work. I'm afraid I may have blown a fuse or fried the ignition switch in one of the many attempts where I had the wires in the wrong places. Is that possible? How can I find out what is wrong now?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Ignition Wiring Diagram lakeboy23 Johnson & Evinrude Outboards 1 February 16th, 2005 08:36 AM
Wiring diagram for 1971 3 cyl 60 hp Evinrude ignition / gearshift harness Tinkerer2 Johnson & Evinrude Outboards 9 January 25th, 2004 01:36 PM
1981 Evinrude 35 hp Ignition Starter Switch Wiring Diagram ryan_scs_inc_outdoorsman Johnson & Evinrude Outboards 2 September 20th, 2003 10:21 PM
wiring diagram for ignition of 1957 Evinrude Lark firemanmiller Johnson & Evinrude Outboards 0 April 21st, 2003 12:36 PM
1990 Evinrude 150 HP V6 Ignition Wiring Diagram Rampart Johnson & Evinrude Outboards 3 June 2nd, 2002 06:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
