Compression check on 1988 Evinrude 40 HP
I just replaced a head gasket and did my first compression check ever.
On a 1988 2 cylinder, Evinrude 40 HP outboard, I read 110 in each cylinder with a leak down check of very little psi for a couple of minutes.
Does this sound right, or should the compression check psi be higher?
Thanks
