mercury 9.9 removing lower unit
I have a 1999 9.9hp mercury long shaft outboard motor. I am trying to replace the water pump, but I cannot figure out how I remove the lower unit. I have unbolted it, but it hangs up on the shift shaft. My manual says to remove the shift shaft retaining clip next to the carbeurator, but I don't see what I am supposed to remove. There is a square bolt with a screw hole in the middle that looks like it connects the shift linkage to the lower unit. The shift linkage is visible, but I cannot figure out how to remove the shift shaft so that I can drop the lower unit. I have this motor partially disassembled now and I would greatly appreciate any help or advice. Thanks, Luke
