Re: 1985 50hp evinrude ignition problem
does the starter turn over or not at all?
if not
check for fully charged battery
all good cables and connectors
clean grounds and tight.
if all looks good and you cant find the problem,
jump the starter directly to see if the starter is ok.
if the starter turns over you have either a bad solenoid or bad connections.
