  #1
Old March 15th, 2007, 10:28 PM
george3405 george3405 is offline
Default Looking for the top plate for choke solenoid 48spl Evinrude (1989)
I've been working on my 1989 Evinrude 48 SPL. After I got it home, I replaced the coil, power pack (Both needed it) and cleaned up the carbs. one of the carb floats was corroded and did not open. The engine has spark and backfires when I hit the ignition switch for the solenoid, but doesn't start. I found that the hose going from the choke solenoid to the top carb is broken off at the solenoid. So, I'm loking for that top plate, held on by 4 screws with 3 hose fittings protruding from it. I think when I get that in order it should start and run.
One question. I've heard when you start the engine cold you should hold the solenoid switch, on the ignition, in for 8 seconds and then release it and start the engine. I've also heard to hold the switch in the whole time you crank the engine til it starts. Any ideas which is correct?
Thanks so much for all the input you all have given me. I'd be lost without y'all.
George3405
  #2
Old March 15th, 2007, 10:47 PM
Walker Walker is offline
Default Re: Looking for the top plate for choke solenoid 48spl Evinrude (1989)
The top for the choke solenoid is availab;e from any dealer or maybe even online.
The recommended starting procedure is to squeeze the primer bulb up tight, turn key to on and push key or choke putton for an 8 count and then start, but holding while cranking works too. You just have to find out which way your motor likes.
  #3
Old March 16th, 2007, 12:35 AM
Walker,
Thank you so much for your quick help. I'll go tomorrow and get the solenoid top and with your starting instructions, I should have it going tomorrow. Again, many thanks!!!
George3405
  #4
Old March 16th, 2007, 08:22 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
after starting i have to bump my key a couple of times until the engine warms up, and settles out.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 1967 60HP choke solenoid Captain'sMate Johnson & Evinrude Outboards 1 July 4th, 2005 11:34 AM
Bad Choke Solenoid Kevincem Force & Chrysler Outboards 3 April 28th, 2005 05:04 AM
1989 Evinrude 48SPL Rough Idle fishnguy Johnson & Evinrude Outboards 7 July 27th, 2004 04:56 PM
Smoking Evinrude Choke Solenoid parsleap Johnson & Evinrude Outboards 2 November 3rd, 2003 11:40 AM
Evinrude Choke Solenoid rterrian Johnson & Evinrude Outboards 2 April 11th, 2003 05:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
