Buying A Used Lower Unit
mekoman
I have a 1991 90hp Force.
Will a 1997 90hp lower unit fit it?
Any help appreciated, Thank You
WillyBWright
Re: Buying A Used Lower Unit
Definately not. They changed to a Mercury style midsection and gearcase in 1995.
roscoe
It may work.
But I don't like that seller.
I have dealt with him in the past, never again.
His listings often have mis-information, and he backs out of deals after you buy and pay for the item.
I see he is up to 34 negatives, and doesn't accept PayPal any more.
That unit has a 2 piece drive shaft, and a single port exhaust (exhaust exits from the exhaust snout above the prop).
Does your current unit have this exhaust type?
Or does it have the exhaust snout AND a through prop hub exhaust also?
You are looking for a unit that came from a 90-120-150 hp, 1990-1994, with 2 piece drive shaft, and either single port or dual port exhaust, whichever matches your current unit.
mekoman
Thanks so much for your help.
This forum is excellent!
May have found something local so that
saves me alot.
