Quicksilver 3000 Classic Remote Control Trim Switch
TommyRox
I need to replace my trim switch on a Quicksilver 3000 Classic remote control and the exploded view that I have found doesn't clearly show how to get to the trim switch. Any help would GREATLY be appreciated.
roscoe
Re: Quicksilver 3000 Classic Remote Control Trim Switch
Push in on the throttle only button at the handle pivot. Push throttle forward. You can now remove the throttle only button by pulling straight out. Remove the now exposed nut, remove handle. Then you remove the shift lock handle (screw). That exposes another screw up near the switch, remove it. Now switch can be removed.
