1998 Mercury 8hp running problem.
djweeks
My '98 mercury outboard 8hp is giving me problems running. I bought recently and it has very few hours of running time. In great shape. The engine idles fine but shuts off when I put it into gear. I let idle for a long time and still the same problem.?????Suggestions????
Laddies
Banned
Re: 1998 Mercury 8hp running problem.
That sounds like a lean condiion, try richening the idle screw 1/4 turn, if that don't help you may need to clean the carb
JUSTINTIME
or trigger arm is no adjusted right
