Mark42
- Oct 8, 2003
- 9,334
Have been looking at 80's and 90's 18-19 foot cuddie cabins. Plan is to convert the cuddy to a pocket cruiser with enclosed cabin.
One of the most expensive parts of a boat is the power. I had planned on using a 100 hp 4 cycle outboard because I feel comfortable with outboards and have experience with them. Also plan on used or rebuilt to conserve expenses. Prices are about $4000 - 6000. That is still a good chunck of money.
Now the problem I have is most boats I see in Cuddy Cabin are inboard powered. Typically a 4 cylinder Mercuiser setup.
So, even if the boat has a bad outdrive, it can be replaced for about $2000 compared to $6000 for the outboard. And still have money left over for engine repairs.
Given the above, which way would you go,keep looking for an outboard powered boat and incure the expense of an outboard motor (I want a 4 cycle), or go with the more common inboard setups and have to go through a big learning curve with inboards?
The boat will be used mostly in salt water moored for a week or two at a time at most. Otherwise, she will be a trailer queen.
Thanks for your comments!
Mark
But I
Mark
But I
