  #1
Old March 9th, 2007, 09:01 PM
lake112 lake112 is offline
Default 1980 Mercury 7.5 Cooling Circuit Issues
I have a 1980 Mercury 7.5 engine that I am cleaning up. When the engine runs there is a lot of smoke coming out of the coolant water exit opening. When I run the engine faster more water and smoke comes out. Is this normal?
Also, when the engine runs at idle speed it seems to have a hick-up. Seems to skip and almost cut off. Any suggestions?
  #2
Old March 9th, 2007, 10:21 PM
emckelvy emckelvy is offline
Default Re: 1980 Mercury 7.5 Cooling Circuit Issues
No, it's not normal. It's an indication of lack of cooling water, so don't run it anymore until you replace the impeller. Overheating is very bad on 2-strokes and it doesn't take many times before the rings/pistons are 'fried' or worse.
There is one nut in the front, and one nut from underneath, to pull the lower unit down. Then (2) nuts hold on the upper water pump body. You'll probably find that the impeller blades are all curled up and have lost their flexibility (and along with it, the ability to pump water).
If the impeller won't come out (very likely), you'll have to split the brass insert of the impeller with a chisel or sharpened screwdriver (my favorite 'cause it's very thin and gets right in there). Be sure to watch out for the impeller key and if it's damaged, replace it along with the impeller.
There's a section in the Repair Forums regarding resurrecting old motors, find the article on impeller replacement and that should help quite a bit.
BTW while the lower unit is off, you'll be able to see the brass water tube which goes to the upper end. Blow air thru this tube and/or run water up the tube to check the rest of the cooling system for any blockages. If air/water flows freely thru the water tube, likely the impeller replacement will resolve your cooling problem.
The idle problem could be related to lack of cooling, it could also be just a lean idle mixture. These motors are quite touchy to carb adjustments, try turning the idle mixture needle CCW approx 1/8 turn and see if it runs better. if this adjustment doesn't help, you may have 'trash' in the carb, which would require you to remove/disassemble/clean it.
HTH & G'luck...........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Merc 110 cooling issues. fastwater Mercury & Mariner Outboards 1 April 17th, 2006 10:08 AM
Need help with 1980 Johnson 35HP (*starting issues) mago01 Johnson & Evinrude Outboards 3 August 17th, 2005 05:00 PM
Merc 9.8hp cooling issues joblo33 Mercury & Mariner Outboards 1 June 1st, 2005 06:31 AM
1980/81 Chrystler Timing Issues jm Other Outboard Brands 7 August 14th, 2002 06:35 PM
1980/81 70HP Chrystler speed issues jm Non-Repair Outboard Discussions 4 June 10th, 2002 12:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
