  #1
Old March 8th, 2007, 03:15 PM
bbcullen bbcullen is offline
Default replacing trim/tilt switch in mercury shifter
I have a 1998 Mercury shifter (controls a 125 hp outboard) unit that the trim/tilt switch has gone bad on. I ordered the new switch and then began trying to figure out how to get the old one out and new one in. the handle is black plastic and seems to not be able to be taken apart. I can see the wires running from the bottom of the shifter and through the hole in the console and they plug into connectors inside the console. That looks easy enough. Does anyone know how to take apart the shifter, remove the old trim/tilt switch and replace it? Does the entire shifter need to be disassembled to do this? Any help is greatly appreciated!
  #2
Old March 8th, 2007, 03:45 PM
DHPMARINE DHPMARINE is offline
Default Re: replacing trim/tilt switch in mercury shifter
Merc/Quicksiver makes a lot of controls,and I don't intend to mislead you ...... BUT
If you need to remove the shift/throttle lever itself,and you have a throttle only button at the pivot point of the handle .... put the control in full forward position.Now you can pry out the button.Then you can see the 11/16 nut that holds the handle on.Before proceeding,move the control lever back to neutral,as it makes reassembly easier.
DHP
  #3
Old March 8th, 2007, 03:50 PM
DHP
  #4
Old March 8th, 2007, 03:56 PM
DHP
It does have the throttle only button at the pivot point. A black button. Do I push in the button and then put the control in full forward position, or do I NOT push in the button and put the throttle in the full forward position? I didn't understand that part. Once in full forward, you are saying that button can be pryed out? then there is a nut that holds the handle on. Do you have to replace the whole handle with switch, or can the switch be removed from the handle? the handle is black plastic (T handle) and the switch is embedded in the handle. Even if I remove the whole handle, I still can't figure out how to take apart the T-handle to get the old switch out. The T handle looks to be in two pieces, but they appear to be glued together. Unless somehow they actually snap together. Not sure.
  #5
Old March 8th, 2007, 04:13 PM
Have it in gear when you push the lever forward,pry out the button.Then return the lever to neutral,and remove the nut and lever.
As I said,they make a lot of controls,but I've posted the basics as I know them.Older controls are even worse.
Most controls are like this,but there are some binnacle (top mounts) that you accually use a razor blade to cut the cover off. Go figure !!
DHP
  #6
Old March 8th, 2007, 04:22 PM
DHP
I found the control on the internet. It is 88688A25 MERCURY O/B TOP MOUNT CONTROL
I'd attach a pic but don't know how. Anyway, I am thinking it's one of those rascals that you have to cut the t handle with a razor to separate the two parts, replace the switch and then glue it back. I hope not, but to be honest, there just doesn't seem to be any other access point. Thanks much!
  #7
Old March 8th, 2007, 04:38 PM
Update on this issue. I used the part number I found and called a local Mercury dealer. He looked up the control and found that you have to replace the handle itself because the tilt/trim switch is integrated and cannot be replaced by itself. Grand total of new handle? $109.
With DHP's help I at least know how to replace it!
thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40HP Mercury Tilt Trim Switch Prob Tim1993 Mercury & Mariner Outboards 2 April 23rd, 2007 11:21 PM
Replacing Power Tilt Switch DScoggins Johnson & Evinrude Outboards 12 March 1st, 2005 07:52 AM
Replacing trim/tilt switch on throttle/gear shifter arm? teds Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 June 2nd, 2003 07:56 PM
Trim and Tilt Switch Mercury Controls JERSATX Boat Topics and Questions (not engine topics) 1 January 2nd, 2003 04:49 PM
tilt and trim limit switch on mercury msbadhabit Mercury & Mariner Outboards 3 December 29th, 2002 07:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
