  #1
Old March 8th, 2007, 12:00 AM
imported_danb imported_danb is offline
Default Submerged Yamaha engine
I have a 1989 Yamaha 200 hp engine which was submerged for about an hour during a rainstorm but then hauled out. It was immediately flushed out and ran to minimize corrosion and the gas was pumped out of the tank. The carburetor was then removed and rebuilt.
After putting the boat back in the water it seemed to run perfectly fine, but after about two hours of running time the engine would slow down even if the throttle was open, when i looked back the bulb was completely compressed as if the engine was starving for gas. I shut off the motor and replaced the fuel filter which is a large white filter not attached to the engine(the engine has a smaller one inside). After replacing it the boat worked fine for another few hours and then the same thing happened again. I replaced the filter several times and the same thing happened every time.
Does anyone know what the problem is? I'm pretty sure that there is no problem with the motor and it may just be something in the fuel line but i am not sure. I would appreciate any advice. Thanks
  #2
Old March 8th, 2007, 03:16 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default Re: Submerged Yamaha engine
did you make sure you have proper ventilation at the tank after your whole ordeal? .....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #3
Old March 8th, 2007, 10:33 AM
Ray Neudecker Ray Neudecker is offline
You also may have to remove or replace the anti siphon fitting at the tank.
  #4
Old March 8th, 2007, 11:55 AM
troypolla troypolla is offline
it sound like its pulling a vacuum in th tank therefore the imploded bulb.
__________________
2005 Key West 186 CC 115Yam. 4-St.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
submerged yamaha 250 searaysrv Yamaha & Suzuki Outboards 3 June 18th, 2006 11:18 AM
submerged engine venture22 Johnson & Evinrude Outboards 0 May 1st, 2006 04:02 AM
Submerged Engine. How bad is it?? Poidda Mercury & Mariner Outboards 5 September 22nd, 2004 10:22 PM
Submerged Engine patjay6666 Yamaha & Suzuki Outboards 8 September 16th, 2004 05:40 PM
Engine submerged...What should I Do ? Karl Seibel Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 June 19th, 2003 08:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
