Re: Smart Tabs recommendation
If you only use the tabs in inland water, small lakes and rivers and want to get on plane faster and stay on plane longer then Smart Tabs is a good way to go.
However if you go offshore or fish big water then get Helm adjustable Trim Tabs like Bennett. They just give you so much more control. Condition change every day or actually every hour. One day you will run 20 MPH in low swells and want very little trim. The next day you will run 9 MPH in big swells and want max trim to keep up on plane at low speed. Next day you will have a 25 MPH cross wind and boat will be leaning into the wind and you will want to level the boat so the deep V works right and to get a dryer ride.
Many days you will be coming in with a big following sea and want no trim at all.
Bottom line for me is with helm adjustable tabs you can adjust for best ride under any conditions. I have a 21 foot Runabout and offshore when it rough I offten adjust every time I change course.
So if all you need is to get on plane faster and stay on plane longer get the cheaper Smart Tabs, if you want full control get helm adjustable Tabs.
