  #1
Old March 7th, 2007, 04:16 AM
d_glover25 d_glover25 is offline
Default low hour mercury 40hp 2 cyl with starting problems
First off, the motor has 20 hrs. and has been sitting for a year. When I started the motor it ran for 10-20 seconds and died, over and over. I changed the fuel tank and and hose and found dirty fuel and leaking hose. still it wont start for long. I checked the fuel filter and after that, it wont start at all. I have no idea what is wrong. the fuel filter was good, very clean, by the way. I tried carb cleaner and found that I could keep it running for as long as I kept spraying in the carb and then it would die as usual. I decided it would be a good idea to check compression again since I found the good tester that had been lost. compression was same in both cylinders, but the bottom plug was clean. I thought it was the carb cleaner. I decided to rebuild the carb with new gaskets and found gum and varnish around th jets. soaked the carb in cleaner and tried to restart. It started at an extremely high idle with the first try. Maybe three more times it started at very high throttle. So I do the linkage adjustment and make sure everything is straight. Now its back to not starting at all. The battery is good and it turns over very strong, but no start. I've read the manual and found nothing like my symptoms. I have found that the fuel pump with a busted diaphram could cause fouling of the plugs(wich are new). but is fouling the same thing as cleaned or wet? I'm really at a loss. the engine is like new. The tank, line, and carb are all good, the only thing left is the pump. is there anyone who knows something about mercs and could lend a hand? I'm really stumped. Please help.
Thanks in advance!
  #2
Old March 7th, 2007, 07:17 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: low hour mercury 40hp 2 cyl with starting problems
It sounds to me like the carb still has a blockage. Sometimes a blockage leaves an air pocket when soaking and the fluid never reaches all of the varnish. After soaking, spray carb cleaner through each and every hole and orifice you can find and make sure it comes out someplace else. Also make sure there is no water in the bottom of the fuel tank. Prop it so that the fill hole is low, then syphon from the low corner of the tank until you have clean gas.
A spotlessly clean sparkplug usually means it's not getting spark.
Instead of using carb spray to start, use a spray bottle with premix fuel. Carb spray washes the oil off the moving parts which can cause serious damage.
Rebuild the fuel pump. Old diaphragms dry out and get stiff and brittle. Kits are cheap and the task is simple.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old March 12th, 2007, 08:05 PM
Thanks Willie,
My motor runs now and I'm about to start with timing and syncronization. I have the manual. I need to get some tools and guages. Any suggestions or tips with the process? Things I should look out for?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 40HP Mercury have trouble starting Iuse2fish Mercury & Mariner Outboards 6 November 1st, 2004 01:25 PM
1994 40HP Mercury have trouble starting Iuse2fish Non-Repair Outboard Discussions 1 October 28th, 2004 05:41 AM
Mercury 9.8 starting problems WhiteBear Mercury & Mariner Outboards 3 May 17th, 2004 08:29 PM
Evinrude Lark 40hp 1969 Starting problems Spitfire Johnson & Evinrude Outboards 5 September 9th, 2002 07:46 PM
Mercury 40hp - 1980 - Starting problems Silverlion Mercury & Mariner Outboards 5 April 26th, 2002 12:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
