R.A. Young
- Dec 18, 2006
- 4
I have 1989 225 Johnson V-6 model # J225TXCED. We have done extensive work on this engine this year.and have replaced the stator, charging rectifier, water pump, vacuum switch, primer solenoid and rebuilt the carburatorsas per specified by the OMC repair manuals. As you come off plane to idle speed the engine seems to struggle to idle as if it was running rich and the engine will spit and the warning horn will chirp one (1) time? The motor will start right back up, but |you have to use the cold start lever to clear the carb's ? Then it idles OK for a short time? Everything seems to be working ok at higher speeds?
