  #1
Old March 2nd, 2007, 11:29 PM
AGENT 37 AGENT 37 is offline
Default 8 Mariner doesn't start... did yesterday
I have a Mariner 8hp, S/N: OD214786, I'm not sure of the year. It was running great three days ago but will no longer start. I checked the kill switches with a multimeter and they are working properly. I pulled the plugs, grounded, and checked for spark. It is present. With plugs pulled I looked into the cylinders and saw fuel mist when pulling start. I attempted to both mist raw fuel into the carb and even tried a little shot of starter fluid into the cyliders and it would not fire. I made a slight adjustment on the fuel control the other day when it was still running because it was flooding out at idle after high rpm. I got it to run perfect. The outboard is pristine and is usually a two-puller. Any tips?
  #2
Old March 3rd, 2007, 08:10 AM
jimlad's Avatar
jimlad jimlad is offline
Default Re: 8 Mariner doesn't start... did yesterday
maybe carb problem when was it last overhauled
__________________
Older enough to know better,young enough not to care--- Ladyfish
  #3
Old March 3rd, 2007, 08:39 AM
Laddies Laddies is offline
The kill switch in the handle cause problems like that unplug it and ck for spark
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #4
Old March 3rd, 2007, 01:15 PM
I already have spark when both of the kill switches are hooked up and the clip switch is in the run position. I Checked both switches with a multimeter at the quick connect (where they come together into an environmental splice); in the run position I have no continuity to ground, in the stop position I have continuity to ground.... both switches. Any idea what reading I should get on the other side..... I have a ground but I assume that is normal ops going into the solid state.
As far as the carb, I didn't have to overhaul it. I simply adjusted the brass srew running into the top of the carb (needle) to adjust the fuel mix. The motor was running when I did this and started after I did this.
Do you folks know what year this motor might be. I'm guessing by apperance to be around 95, if not newer.
  #5
Old March 3rd, 2007, 01:17 PM
I don't have a book yet, that's why I'm asking for electrical help, otherwise I'd just look at the wiring diagram. Thanks.
  #6
Old March 3rd, 2007, 01:40 PM
jimlad's Avatar
disconnect kill switch and try and start it if not it maybe switchbox
__________________
  #7
Old March 3rd, 2007, 01:43 PM
Plainsman's Avatar
Plainsman Plainsman is offline
0D182000 - 0D280999
1993
Also don't use starting fluid or raw gas to start. Use a premix.
If your seeing fuel in the cylinder, then I would think it was a spark issue. I know you said you have spark, but is it a good blue spark and how did you test it?
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #8
Old March 3rd, 2007, 02:08 PM
emckelvy emckelvy is offline
If it wouldn't fire even with starter fluid I'd say you're running too rich (that is if you are absolutely sure there's good spark).
Perhaps fuel pump problem or carb problem. If your carb has a primer valve vs. choke butterfly, and that primer ckt is stuck open, it'll flood the engine. Or maybe a leaking carb float needle/seat.
A leaking fuel pump diaphragm would be another thing to look for.
On the spark thing, if you have a timing light you can clip the pickup around each spark plug lead and check for firing indication with the plug installed in the cylinder. This way you'll know for sure you're getting spark under pressure.
Or a cheap neon firing indicator, commonly available at auto parts stores.
You can make your own spark testing tool by clipping the ground electrode off an old spark plug; if the spark jumps the resultant gap, it should be of adequate strength to fire under compression. You'll find this type of spark tester at many auto parts stores, too.
Here's a few typical examples:
http://www.thetoolwarehouse.net/shop/TTW409.html
http://www.nextag.com/spark-tester/search-html
HTH & keep us posted..........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mariner 225 efi will not start aaoliver Mercury & Mariner Outboards 13 September 8th, 2005 07:56 AM
MARINER 150 EFI WON'T START JCARROLL Mercury & Mariner Outboards 1 October 3rd, 2004 12:48 PM
mariner 90 non start atlantic Mercury & Mariner Outboards 1 June 3rd, 2004 04:37 AM
Mariner 25 doesn't start when hot ernie6283 Mercury & Mariner Outboards 0 July 14th, 2003 07:15 AM
30 Hp Mariner WILL NOT START FROM KEY..... newbowhunk Mercury & Mariner Outboards 13 March 20th, 2003 11:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
