iboats has a sale on OMC 4 stroke props......what?
Texasmark
My curiousity is at it again. Why do you have to have a special prop for 4's? I noticed a thread from Dhadley the other day that said that if you don't keep them at or over 6000 at WOT they'll load up fast.
Is there a 4 stroke message here that potential 4 stroke purchasers should know about?
Thanks,
Mark
Ron G
Re: iboats has a sale on OMC 4 stroke props......what?
I think its because they dont spool up as quick as a 2 stroke and dont have as much bottom torquethere also heaver so may need a prop with some stern lift too,but i dont know.
WillyBWright
They're probably Suzuki props.
walleyehed
Johnsuki is correct....
Let's say BRP needed some help unloading some props....
lowe160
I run a Suki prop on my Johnson and so far is the best prop but still searching. I have a 5-6 sec. holeshot but have not yet vented it. I have not heard of any loading up and many are used for trolling? The props are not special for my 50 HP as the DT50,55 etc. are the same prop.
Wayne
