imported_boatrookie
- Nov 10, 2006
- 51
I know some of you guys read my problem i had with my boat at a repair shop. how they charged me for carb work that was supposed to fix the problem i was having with my boat not wanting to start or run, and only to fiend out it was something totally different,(no spark) that they did not even test until after they did the work on the carbs.
I sent PM to some of you guys asking what is the standard procedure to test a engine when it will not start. only one answered back, so i want to ask all of you what are the first things you check to see what is causing the problem? is there a standard check list you would do to narrow down where the problem is or do you just take a whack at it and see what happens, changing this and that until you finally get it right.
Please answer back on this one.
