Re: 2002 johnson 90hp running problem
Did your mechanic check the fuel line all the way to the tank pickup? You may have debris on the pickup screen, a cracked pickup tube, a sticking anti-syphon valve in the tank outlet, etc. Sounds like a fuel starvation problem, especially since it gets worse at higher power settings. Also, any air leak into the fuel line will cause starvation. IO would suggest looking at a shop manual for an organized check list of things to look for. Good luck!
Several things you might try to confirm fuel starvation: 1) try activating the choke/primer at high power to see if the running issue momentarily clears or, 2) spray fuel/oil mix into the carb throats while at high power. CAUTION: Do not operate the motor any longer than absolutely necessary will the inlet air silencer removed!
I really hate wrenches that just start throwing new parts at a motor, hoping one of them may fix the complaint.
