Re: Lower leg Removal 2003 75hp 4 Stroke Mercury
IF you have the 4 bolts and 1 nut off, it should come off.
It may be stuck on the alignment dowels. I usually tap them with a mallet near the back (DO NOT hit the cavitation plate) of the lower to get it to pop loose. The shift linkage is splined and should just pull apart.
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
