  #1
Old February 25th, 2007, 05:07 PM
caithnessdiver caithnessdiver is offline
Default Power trim problem on Mariner 135HP
Hi folks,
Greetings from the far north of Scotland. I only just found this site and there seems to be a lot of useful stuff.
I have a Mariner 135HP on a RIB (built 1989), which has been lying unused outside for several tears. I decided that this was a waste and I'm in the process of refurbishing the boat and engine. The power tilt worked OK when I put in a battery, but it stops with a clunk when it reaches the two smaller trim pistons. The motor keeps running, but there is no further movement. Has anyone come across this problem and if so, how was it solved? I don't have a manual for the engine at the moment, but one has been ordered.
  #2
Old February 25th, 2007, 05:08 PM
Default Re: Power trim problem on Mariner 135HP
I meant 'several years' of course, but there may yet be tears!!
  #3
Old February 25th, 2007, 05:40 PM
Plainsman's Avatar
Plainsman Plainsman is offline
Have you checked the fluid level? What is the serial #?
You may want to check this out as well:
http://forums.iboats.com/bbBoard.cgi...6;gtid=1035575
And Welcome to iboats!!
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #4
Old February 25th, 2007, 06:51 PM
Laddies Laddies is offline
OK. after a couple people asking for a serial number on a couple of differant threads I won't waste my time---There are two differant hyd. systems on the early 135s so it makes it alot easier for us to explain
Chances are it's one of three posablitys and all are pressure related
1 The pump motor is shot--it will slow down to nothing
2 A pressure relief ball on the tilt cyl is stuck
3 The seal ring on the tilt cyl is leaking
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #5
Old February 26th, 2007, 11:19 AM
The motor sounds pretty lively and there is no sign of external leakage of fluid, so I'm getting the feeling that something internal is stuck, maybe due to sitting for a while. Would opening the manual release to allow the engine to drop completely exercise the valves in the trim piston section?
I can't do too much without the manual, but when I get it and have got to the bottom of the problem, I'll post a note of what happened to help any fellow sufferers. Thanks to those who have replied - it's helping to focus my mind.
  #6
Old February 26th, 2007, 11:24 AM
Don S's Avatar
Don S Don S is offline
It sure wouldn't hurt to open the manual release and try it, you might also have someone run the trim button down and you stand on the drive and bounce it a bit. If it is just stuck from sitting the extra weight sometimes works.
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #7
Old February 26th, 2007, 07:17 PM
Bouncing on the drive sounds like a good idea. I've got a heavy friend who can help while I press the button.
  #8
Old February 27th, 2007, 06:13 PM
Maximum points to Don S!!! My heavy friend bounced on the leg of the engine and the trim pistons are now running freely. Sometimes only the right amount of brute force will do - Thanks!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 MARINER 135HP P/TRIM INFO jgoose Mercury & Mariner Outboards 0 August 30th, 2006 01:30 PM
1997 135hp mariner, p/trim problems jgoose Mercury & Mariner Outboards 0 June 28th, 2006 09:28 PM
84 Mariner Power Trim reubanks Mercury & Mariner Outboards 3 June 8th, 2005 05:18 AM
Power Trim on 1988 Sea Ray (Mercury) 135hp jgray007 Mercury & Mariner Outboards 0 June 1st, 2005 10:38 AM
Power trim, 87 150 HP. Mariner Jimmy T. Mercury & Mariner Outboards 0 October 24th, 2003 09:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
