Motor will set and idle and also wind up, but it has a miss in all rpm ranges. I definately think its fuel related. I think it might be the fuel pump. Does that sound like a possible cause? Was also wondering if a bad primer solenoid would cause a miss? I ask because the primer solenoid was full of trash and the lines connected to it as well. I cleaned them and tested the solenoid and it pumps, somewhat weak, but it pumps.
P.S. This is with earphones not in the water...
Thanks
Thanks
