I just rebuilt carbs and installed them, tryed to start motor. it took a few trys then started up for a few seconds. you can see fuel going to carbs, but fuel is also squirting out of lower carbs fuel bowl jet vent, should this be happening, it seems that a excessive amount of fuel is coming out and leaking in to the motor houseing, any ideas would be appriciated
okay I fixed the floats now, the motor starts, and there is no excessive fuel icoming out . But when I go to put the warm up lever down the motor dies out after about 3 seconds, any ideas as to why. thanks for all your help so far
First I want to thank Laddies for all the help you have provided to me so far. This might be a dumb question but is it bad to run the motor in gear with the warm up lever pulled up, and what purpose does the warm up lever really serve. This is my first boat so I am just learning as I go, the man who sold it to me was hard of hearing and it was hard to get answers from him.
The warm up lever is nothing more than a throttle in neutral.
But you still don't want to run the engine at too high an rpm. So you have to monitor it.
Keep it in the 1500 to 2000 range for the first few seconds till it will run on it's own, then let it idle.
After a rebuild, the carbs will need an idle mixture adjustment. The book settings are nothing more than a starting point for the mixture screws.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
