1989 mercruiser 5.7L help needed pleae.
well as most of you guys know i alway have some issue with this enging,
yesterday i decided to change the spark plugs and have a good look to see how each cilinder is burning.
reason from day one i seems to get a little staem from the port valve cover , and after a long run if i shut down and fish for say 30 min and when try to restart the engine spins slow but it catch every time.
the engine runs great but i can only get 30 miles per gps at 4000 rpm and it will go no more only 4000 rpm even if i drop down in prop size it just seems to stop at 4000 rpm,
i bought a new tach and both reads the same.
anyway guys i pull the sparkplugs and the two back plugs on the port side cilinder seem like they did not fire they look real clean. but the other two has the normal wear looks.
on the starboard side the back ones look kinda clean too only one looks real wear.
my compression is on all cilinder 145 to 150,
so guys is this a head gasket issue or a crack block???
the risers and manifolds is new not even a season old,
also will a bad intake gasket cause water to enter a cilinder??
last the oil is super clean no milky stuff, i just change it and it look real clean.
any info will help guys i have two more togs trip plan before i pull for the season, i just dont knoe how to do that darn leakdown test well i might pay the mechanic to do that for me.
thanks for whatever info you guys got.
1989 merc 5.7
1989 merc 5.7
