hello guys happy thanksgiving to all.
my friend carver that he has bought late summer , did not has no speed, so after power wash all the barnicle from the hull he got a little speed from it.
last week going to the sandyhook reef with four guys and a full tank of gas the boat only got 3500 all out rpm and about 15 miles per gps.
there is a sound coming from the back of the engine when it is running, real coarse rubbing sound,
warm up the engine compression test read all cilinders from 123 to 125 all.
that only the dry test did not do a wet test.
now we haul the boat the gimball bering seems kinda good its spins freely by hand.
now decided to let the lower unit oil out, oops no oil coming out only thick stuff milky real thick too ,
so i know that unit has water in there, could that be the reason the boat did not have any speed??
can this drive be save/rebuilt??
the spline on the drive did not look eaten of but he plan to change the coupler anyway, reason the two front engine mount was not connect to the hull it rot out so i ges the alignment was a mess.
thank for any info on this.
