shipwreck
- Nov 23, 2006
- 263
i just bought this boat i test drove it, the engine run great, but the throttle cables need replaced.
it mercury 650 1964 or 1965 four cycle striaght.
it has two cables first goes to the magneto/ throttle , the other one is for warm up lever.
my problem i can't get hooked up, bought to new cables telefex 650a's which all the material says they are the ticket ( the right one)
i have my throttle box in netural( level striaght Up) and can attach to the motor.
first question dose this motor have reverse?
the propper will only rotate clock wise on the motor, so i moved the dis/ magneto which moves the butterflys on the carbs even more open but dosen't cahnge it the reverse.... that is if the engine has reverse at all?
where would i start to hook up these cables ....wright the way
dose the warm gear changer gears to reverse?
or dose just do nothing other then advance the throttle to warm the engine without it be in gear?
i read to book i bought and ask many people hopfully some can tell where to start , a book , a person in westerville ohio that works on old engines
in short help!!!!!!!!!!!!!!!!!
