Greetings all! Wish I was coming here on a better note but unfortunately I had a run in with a submerged log while duck hunting last week and have done the lower unit bad. The housing is in good shape, no noticeable cracks or bends. The prop won't turn, unless under pressure it will skip a few teeth on the gear. I can still shift through the gears without any troubles. With that limited amount of information, anyone have a diagnosis?
A little more info, the motor is a 1986 Johnson E40ELCDE tiller. I figure I better start looking for parts, can someone tell what model years (and hp) are compatible with this series of motor?
Thanks for the help, I'm sure I'll have more questions as this progresses.:%
