garymac999
- Nov 17, 2006
- 2
I have a 2006 - 3.0 litre mercruiser alpha I which has the fuel enrichment feature for cold starts. The fuel enrichment is supposed to disengage when the engine reaches normal operating temperature of 170 degrees. However, this does not occur and the engine is running extremely rich. The only way to get it to disengage is to shut off the motor, let it sit for a couple of minutes. After restarting, it then runs fine. I have had it to the dealer three times, but all they do is adjust the carb and this has not cured the problem. Does anyone have any suggestions that I may take to the dealer? I think there must be temperature sensors that are not working right but I don't have the factory service manuals.
