I think I have a problem with the nuetral switch. The starter button will only engage the starter if I remove the engine cover and push all the way down on the cam / lever that pushes in the little button on the bottom of the neutral switch. Am I on the right track? Is there a way to adjust the postioning of the neutral switch or the lever? Or do I need to replace the switch?
Performing this delicate starting procedure can be tricky when duck hunting in the dark, gloves on, etc.
