mariner 75hp 1997
raptorheli2
got an issue with a mariner 75hp 3 cyclinder.
basically it's sparking intermittantly. initally it will spark on all cylinders for a few secs. try it again and it'll be down to 2, then again down to 1. leave it for 15 mins and try again and it might go back to 3 sparking and then 2, then 1 etc etc. the top cylinder always sparks and the other 2 will go between the intermittantly.
the problem occured while running and i know one cdm was gone so i replaced that and also the trigger but it has not fixed the issue. i put the engine into the local outboard place but they have had it a week now and there isn't a lot of progress because of waiting on a trigger (which didn't fix it)and a cdm tester coming (they don't have one).
this is the diagram for it
http://www.mercruiserparts.com/Show...ECTRICAL++(USA-S/N-0G438000/BEL-9937000+&+UP)
anyone any ideas what this could be? i have been told possible cdm but they all do spark at some point then lose it which says to me it could be the voltage regultor can't supply the power properly sustained or the stator isn't giving it power in first place????
just would like some sort of idea as i can see me ordering parts constantly, already got a trigger i didn't need but thats part of the fixing process i guess.
thanks
JUSTINTIME
Re: mariner 75hp 1997
CDM#1 gets its charging ground path through CDM#2 or #3
CDM #2 and #3 get their charging ground through CDM#1
a shorted stop diode in CDM#1 would prevent #2 and #3 from sparking
a shorted stop diode in #2 or #3 will prevent #1 from sparking
rectifier has nothing to do with this
the stator has something to do with this
obvious the mechs have no idea how to trouble shoot
make sure they have the manual and follow step by step, u can not make short cuts in trouble shooting these motors! these motors are on of the hardest to troubleshoot and sync and link because u HAVE TO FOLLOW THE MANUAL STEP BY STEP
raptorheli2
hi there
thanks for the response. i have no idea (hence i put it into repair place) what it could be. but i figured the next thing was the cdm's and he has a tester coming for them.
i'll find out more next couple days and see what happens.
cheers
